Sony Lamps -- Durability?
Discussion in 'Displays' started by Matth_S, Apr 25, 2004.
  1. Matth_S
    Matth_S Auditioning
    Apr 25, 2004
    I've recently purchased a Sony KP51WS510.
    I'm curious.. How long should the lamp last on this model and how much does it cost to replace?
    Thanks!
  2. Jason Charlton
    Jason Charlton Ambassador
    May 16, 2002
    3,556
    413
    Baltimore, MD
    Jason Charlton
    The Sony KP51WS510 is a CRT-Based RPTV - it does not have a "lamp" per se that is user-replaceable (you're probably thinking of DLP and LCD-based sets which do).
    CRT-Based sets have 3 CRTs (red, blue, green). Over several years time, they will dim and eventually they may require replacement, and that is an expensive repair (in the neighborhood of $1000).
    Don't let that scare you, though. If you properly calibrate your set with AVIA or DVE, set your contrast down to 30-40%, and use "common sense" and take care of your set, you'll be in the market for a new set long before your current set becomes unwatchable. Besides, the dimming effect happens VERY slowly, over many years. You'll probably not really notice the change.
    -Jason
