Sony KV-36XBR800 - Matching DVD Player
Discussion in 'Displays' started by Shaown, Jul 17, 2003.
  1. Shaown
    Shaown Agent
    Jun 4, 1999
    37
    Hi folks,
    I'm picking up the Sony 36 inch HD (KV-36XBR800)(used), and looking for the right DVD Player to match to it.
    First, I currently have SONY NS315 (pretty recent, non-progressive low end player).
    I can't spend a lot after buying the TV (well not for 6 months or so), so I figure I have some options
    1) Keep current player and depend on the TV to handle the cleanup
    2) Pick up ultra cheap progressive
  2. Brent Hutto
    Brent Hutto Supporting Actor
    Aug 30, 2001
    532
    The de-interlacing in the 36XBR800 is quite good. We use a Panasonic RP82 DVD player and I somewhat prefer its picture to what we had with our previous RV26 but it's a small difference. My wife doesn't notice any difference at all between letting the TV and the player do the de-interlacing.
    I wouldd think that a super-el-cheapo progressive-scan player could possibly not do as good a job as the 36XBR800 will do for you. If your current player is reliable I'd not replace it unless it was with a progressive-scan one per se unless you find a good-quality one you like.
  3. Shaown
    Shaown Agent
    Jun 4, 1999
    37
    Interesting, so just hanging onto my player for now may not be a mistake!
