Sony KP-61HS10
Discussion in 'Archived Threads 2001-2004' started by Anthony Sa, Jan 22, 2002.
  1. Anthony Sa
    Anthony Sa Agent
    Dec 6, 2001
    40
    My parents have a Sony 61HS10 and I wanted to know if it would accept BNC inputs for RGB. They can not find the manual and I can not find the information online. I am assuming it only accepts RCA but I would like to make sure because I would rather use BNC connectors.
  2. Ergin Guney
    Ergin Guney Agent
    May 24, 1999
    36
    Perhaps you're only asking this because it's difficult to reach the back of your parents' set, but if it isn't, it's a simple matter to tell the two apart just by the appearance of the jack itself.
    A BNC jack typically looks like the following:
    BNC example (The one on the left.)
    An RCA jack typically looks like the following:
    RCA example
    Of course, only the metal tip of each type of jack will be visible in the back of any TV.
  3. Jay Mitchosky
    Jay Mitchosky Producer
    Sep 6, 1998
    3,729
    I can't think of any consumer level RPTV that uses BNCs.
  4. Anthony Sa
    Anthony Sa Agent
    Dec 6, 2001
    40
    Yes it is extremely difficult to reach the back without moving a ton of stuff out of the way. They have it caddy-cornered with a desk on one side and a cabinet on the other and I did not feel like crawling back there. I was assuming no on the BNC so thanks for confirming my thoughts!
  5. JohnDG
    JohnDG Stunt Coordinator
    Jul 15, 2000
    238
    You can get BNC/RCA adapters plugs at Radio Shack.
    jdg
