Sony KDS-R50XBR1- Yellow Screen Blob
Discussion in 'Displays' started by Philm35, Aug 5, 2006.
  1. Philm35
    Philm35 Auditioning
    Aug 5, 2006
    7
    I have an eight month old Sony KDS-R50XBR1 LCoS TV. In the last couple of weeks, I've noticed a "blob" of slight yellow tint about 10" in diameter at the lower edge of the screen about 1/4 of the screen width from the right.
    It stays there consistently, and is usually only visible over a gray picture area, such as seen with black and white images. It is always visible when watching 4x3 pictures in the gray area to the right of the 4x3 image.
    Any thoughts on what might be causing this, and how to fix it?
    --Phil
  2. Adam_R
    Adam_R Second Unit
    Jul 10, 2002
    395
    sounds like what a magnet will do to a CRT
    do you have unshielded speakers near the set?
  3. TonyD
    TonyD Who do we think I am?
    Dec 1, 1999
    17,398
    520
    9,110
    Gulf Coast
    Tony D.
    this has been an issue with the sony xbr line.
    i dont have a lik but there is a long thread o this over at avs
  4. Philm35
    Philm35 Auditioning
    Aug 5, 2006
    7
    Hi Adam--
    I have a Klipsch center channel speaker on a shelf below the TV, but it should be shielded adequately. I tried removing it to look for a difference, but found none.
    And Tony-- pardon my ignorance, but what is avs, and how can I search for that info?
    --Phil
  5. TonyD
    Dec 1, 1999
    17,398
    520
    9,110
    Gulf Coast
    Tony D.
  6. Philm35
    Philm35 Auditioning
    Aug 5, 2006
    7
    Thanks, Tony. I found the site... there is a wealth of info about the Sony XBRs there. Awesome.
    --Phil
  7. ChrisWiggles
    ChrisWiggles Producer
    Aug 19, 2002
    4,791
    No, it's an LCOS display, the issue is not related to magnetic fields.
    "greenblob" problem.
  8. Philm35
    Philm35 Auditioning
    Aug 5, 2006
    7
    That's what I initially thought, too... How can a magnet affect an LCoS chip? But interestingly, Sony's troubleshooting website lists magnetic fields as a potential source of picture problems. I'm just not sure how.
    The avs website has a huge thread on this topic... apparently many early examples of this TV suffer from the problem. The fix is to get Sony to replace the optical block under warranty.
    --Phil
