ArmSC
Nice! Congrats on getting your system off the ground.bjballar41 said:I have the speakers. Box is a lil torn so I hope nothing is damaged
I've not heard too much about it either way. With it being over $300 you're starting to get up into the budget of some better subs. I would do some research and see what you can find...I just don't know.iTylerA said:Do you have any thoughts on the PL200 Tony? I'm thinking my next speakers are going to be the Acoustech series and that is the sub from that series
Now you need some stands or use existing furniture you have around. You want to get your tweeter to about ear level while sitting in front of the TV. I like the stands because they can be adjusted to the right height. If you end up getting towers you just move them to the rear position and you're good.bjballar41 said:Wow these things are a lot bigger not sure where to put them now. Lol
I didn't even think about that...mine was hooked up to the network straight away and it did do a few updates when I pulled it out of the box.schan1269 said:The AVR probably needs some updates.
