Sony HS10 banding fix?
Discussion in 'Archived Threads 2001-2004' started by Matt Anderson, Aug 22, 2001.
  1. Matt Anderson
    Matt Anderson Auditioning
    Dec 3, 1999
    2
    I've had my sony hs10 for about a year. I've read about the banding problem but haven't been able to find an official fix for this. Is there any?
    Matt
  2. Mike Emery
    Mike Emery Auditioning
    Sep 29, 1999
    10
    There is a fix, involving some changes to values in the service menu.
    If you're still under warranty (actually, even if you're not.... since it's an engineering/manufacturing defect) call Sony's service center at 800-222-7669 and request a service call to correct the factory defect.
    Some units of the 16:9 xxXBR10W also exhibits banding. I would think that the same fix would be applied...
  3. Abdul Jalib
    Abdul Jalib Stunt Coordinator
    Dec 27, 2000
    175
  4. Mike Emery
    Sep 29, 1999
    10
    Right, I forgot about that (must be some merciful mental mechanism at work!)
    They may also change a small "chip" capacitor (which sometimes doesn't help, either!)
    Doesn't hurt to call.
  5. Matt Anderson
    Dec 3, 1999
    2
    Thanks for the info guys! I remember these being discussed earlier on. I didn't want to react right away incase of any side effects and lack of expertise on my end to know any better [​IMG] I was hoping if I waited it out that sony would eventually have the problem solved.. apparently not [​IMG] Hopefully they'll send someone who knows what they're doing and more importantly has anyone EVER had any ILL effects from getting either of the "work arounds" (thanks sony) done?
    Thanks!
    Matt
  6. Steve Schaffer
    Steve Schaffer Producer
    Apr 15, 1999
    3,756
    Does anyone know if the fix was incorporated into later production models of the HS-10, or in the new HS-30 models?
    Good Guys here in CA has the HS-10 marked down to $2199, and a 4/3 set that squeezes would be the perfect solution for my particular needs.
    Steve S.
    I prefer not to push the subwoofers until they're properly run in.
  7. Fred B. Humphrey
    Fred B. Humphrey Auditioning
    Jun 30, 2001
    6
    I have the Sony HS10 and have heard of this problem.
    What is it exactly? How do you tell if you 'have' it?
    Is it a subtle problem? Or does it affect only some sets? I've never noticed anything wrong with my 1 year old set. Thanks. Fred.
