Sony hdtv KP-65wv600
Discussion in 'Home Theater Projects' started by Jim Far, Mar 2, 2004.
  1. Jim Far
    Jim Far Extra
    Jan 7, 2003
    15
    Has anyone had problems with flickering on the Sony KP-65wv600? I have had this problem for a couple of months and appears to be getting worse.
  2. Gary Mui
    Gary Mui Agent
    Dec 5, 2002
    35
    I have the KP-65WV700 and I had flicker problems. Call your local Sony Service Center and get them to fix it, it's covered under warranty as it was a defect:
    http://products.sel.sony.com/SEL/ser.../flicker.shtml
    You should do a search for this "flicker" problem, it's been well documented already.
  3. Jim Far
    Jim Far Extra
    Jan 7, 2003
    15
    Thanks Gary!! I have called Sony. I'm outside the year warranty, but the article says they will fix it anyway..I am waiting for the local service center to investigate.
    Thanks again..
