Darren K Price
Grip
- Aug 8, 2001
Anyone have any technical repair ideas regarding a Sony DVP S7000? We had just finished watching the Mummy Returns and I was putting in The Planet of the Apes. The tray loaded the disc, the front panel display was lit while the DVD player assessed what type of disc I loaded then the display went black and the power turned off. I couldnt even get the thing to let me get the disc out. I though it had bed caused by a bad disc from Blockbuster (after I took the unit apart and removed the disc I noticed that the disc was FILTHY). I will know better next time to clean them. I had to disassemble the unitto get the disc out. Well, since I had the unit apart, I checked all of the connections but still no front panel display. Here are the symptoms: no front panel display, it will power on for only a moment then shut down and I cant get the tray mechanism to load/unload. Sound familiar to anyone?
Darren K Price
Darren K Price
