Sony DVP-NS700P & WEGA
Discussion in 'Archived Threads 2001-2004' started by david spin, Feb 6, 2002.
  1. david spin
    david spin Auditioning
    Feb 5, 2002
    7
    Hi
    I have the WEGA KV-36FV26 (not digital) and have been using a panasonic dvd player connected to it via component cables.
    It (the player) died and I was thinking about getting the Sony DVP-NS700P. I plan on getting a tv that can handle progressive scan in the future so that's why I like this player. My question is that can I still use the component cables to hook it to my tv even though I dont use progressive scan?
    Thanks!
    Dave
  2. Matt DeVillier
    Matt DeVillier Supporting Actor
    Sep 3, 1999
    773
    in a word, yes. 99% of prog scan units allow you to switch between interlaced and progressive for the component outputs
  3. Dmitry
    Dmitry Supporting Actor
    Nov 30, 1998
    740
    Sony DVP-NS700P belongs to one of these 99%. It has a selector on the back that allows you to switch between progressive, interlaced and selectable output. If you choose selectable you select the output format through the menu.
