SONY DVP-NS300 dvd player (1 Viewer)
Kevin.Kh
Uhm... I'm having difficulties getting into the MENU with this dvd player. I dont have the original remote for this dvd player, but I'm using another SONY CONTROLLER and when I try to get to the menu screen, it saids 'button is not useable now"
The reason why I need to go in the menu is to setup my speaker setup because I have Optic Cables and it seems like my sound does not work...
JamesCB
Is the sony controller you are using a programable type? Most programable remotes have several codes for similar components. You may have to try another code.
James
Righ
