Robert_B
- Feb 14, 2000
I have a Sony 5-disc changer (DVP-NC655P) that is about 1 year old and it cost about $229 or so... Anyway, it will not recognize a DVD or CD... It cycles through all 5 and tries to read... after each one fails the led for that disc is turned-off... until all of ths disks fail...
BTW: this has happened before with the same model and it was switched out via Best Buy long after the 30 day period...
Ultimately, the display reads "No Disc".
Any thoughts on a quick fix?
What is likely the problem?
Ever heard of such a thing?
What would it likely take to fix it?
If you think it is toast and/or not worth fixing, what do you recommend I do? Get a cheap replacement like $100-$200 range? Or, get something like a Denon 2200 for $500 or so...?
One more thing, I did run this player quite a bit... several hours per day during most days...
