Steve-AZ
- Aug 12, 2002
DA5ES Owners:
I recently purchased a Sony SACD/DVD unit (NC650V) to add to my HT system and have been trying to "decode" both the DA5es and SACD/DVD operating manuals to determine how they should be connected to get both of the SACD and DVD functions into the DA5ES. Since the DA5ES operates uniquely on the inputs, I thought I would see what the other DA5ES people are doing.
From what I've read, you need to feed 5 analog lines from the SACD/DVD 5.1 Multi CH output to the DA5ES Multi CH input to get the SACD. This bypasses the surround effects of the DA5ES and when this input mode is selected the surround fields can't be used. You can use the limited surround fields in the SACD/DVD unit, however.
To get the DVD signal into the DA5ES and use the DA5ES surround fields, you need to run a digital or optical line into the DA5ES.
Thus you have two "sets" of interconnects - (1) analog (5 lines)for the SACD and with no surround fields from the DA5ES and (2) another digital interconnect for the DVD signals and with the DA5ES surround fields. You just select the input mode on the receiver depending what's in the SACD/DVD player.
Is this right?
I hate to by more cables than I need!
Is this right?
