Michael Knieriemen
- May 28, 2000
For those DA5ES owners, did this upgrade add any functionality to your receiver (like dts 96/24)?I haven't noticed anything new features yet.
I have been trying to download the new firmware version on to my 4ES since last night and no suscess...My 4ES also does not dislay the firmware version, but only the model number, when using the trick for the 5ES (scrolling the jog dial all the way). Your receiver may already have that version of firmware (or maybe even a newer one) which would explain why it isn't letting the upgrade take place.
There is another thread describing the update and it gives specific model numbers. I cannot find the thread (server won't do searches due to high load) but it indicated that the upgrade was for 4ES receivers with serial numbers in the range: 8800001 through 8805418. Check your serial number.
4ES receivers with serial numbers in the range: 8800001 through 8805418. Check your serial number.I remember that thread, my 4ES does fall in that range but my 4ES has been properly decoding the disc that were giving 5ES owners probems. I figured since Sony put out the upgrade for the 4ES&7ES then if you own one you need to apply the upgrade.
I have notice on my 007 Tommorow Never Dies it does not say it is DDEX but my receiver says it is. I keep mine on auto dec, when i put in Star Wars AOTC and other DDEX disc the 4ES does not go into SB Decoding only with DTSES it will go into SB Decoding. So is this upgrade going to make the 4ES detect all DDEX disc?
One more question. Aaron does your 4ES decode Star Wars AOTC and other DDEX disc the same as mine? If so then i might not need the upgrade.
...when i put in Star Wars AOTC and other DDEX disc the 4ES does not go into SB Decoding only with DTSES it will go into SB Decoding. So is this upgrade going to make the 4ES detect all DDEX disc?The reason for this is simple: the DD-EX flag is not set in the bitstream. It most certainly is recorded in EX though. You have to set the SB decoding manually for most DD-EX titles. This is not the case for dts-ES tracks though. The reason is that some older DD decoders had problems with soundtracks that had the EX flag set, so Dolby now recommends not setting the flag at all. Some DVD's have the flag set correctly, and some do not.
(I can check later today if my 4ES enables SB decoding for DD on Episode 1, but I am fairly certain that it will not!).
