Thomas_Riel
- Dec 1, 2001
I'm hoping you guys can help me out. I have a Sony DA4ES driving Energy C-2s in the front, an AC300 center and C-1s for surrounds. I just purchased a HSU STF-2 sub-woofer. I have all speakers set to small and I have the sub-woofer set to out using the DA4ES internal crossover. I have lowered the LFE High Cut crossover to 80Hz with all the other speakers set to the 120Hz which is standard on the DA4ES. My question is should I set all the speaker crossover settings to the same setting as the LFE High Cut crossover?
Thanks...................... Tom
