Sony Blu(es) HDMI Question (1 Viewer)
FrankLambert
Franklin Lambert
My Sony Manual has that I need at least 6.68Gbps HDMI cable..with all the confusion out there about Monster and such..any suggestions that may clear this up for me ..thanks for any assistance
David Willow
Babbling Idiot
Mechanicsburg, PA
Dave
Hi Franklin,
Here's a great place to purchase and read all about cables: HDMI Cables from Blue Jeans Cable
You can check out monoprice.com as well. They are another excellent vendor.
Don't buy into the hype that Mon$ter sells. Any decent cable will work. Just make sure it is marked "1.3".
zoobird
