John H Ross
- Oct 16, 2000
Hi,
I'm reasonably happy with the way my Sony 7700 DVD player handles layer changes. They are generally smooth and quick (usually less than a second).
However, I have noticed a disturbing trend. When the second layer begins, the first second of film is usually displayed without sound. Usually this doesn't cause a problem, but if there's dialogue immediately after the layer change, it can be cut.
I believe this may be the fault of the amplifyer (Yamaha DSP-A1) which requires a second to re-adjust to the appropriate sound format being used. Is this true and, if so, is there anything I can do about it?
Thanks!
Thanks!
