Sony 57-WV600 or 57-WV700?
Discussion in 'Archived Threads 2001-2004' started by Chris James, Aug 18, 2002.
  1. Chris James
    Chris James Stunt Coordinator
    May 13, 2002
    142
    Ok, I am going to get one of these SOON. Now, I need help deciding which I should get. From all the information I can find, the biggest difference is the new screen material on the 700 which helps off-center viewing. Is there anything else major that would make this set worth the extra price over the 600 series? I hope some of you can help me out!
    And, yes, these are the only two I am considering purchasing. My house "decor" is perfect for the pewter color. I don't want a black box looming there.
  2. Chris James
    May 13, 2002
    142
    Ok, I'll try elsewhere.
    /me slinks back over to the Speakers and Subwoofers forum....
  3. Kyle Richardson
    Kyle Richardson Screenwriter
    Jan 1, 1998
    1,073
    Chris, I am wondering the exact same thing so if somebody knows please let us know. If there isnt much more than the different screen then the 600 gets my vote.
  4. James Stierman
    James Stierman Stunt Coordinator
    Jul 21, 2002
    88
    Yeah the 700 series will only help you if your viewing on off angles. So if you aren't theres nop reason to go with the different screen.
