Yogi
- Jul 25, 2002
Aaron, thanks for the clarification. I am not really familiar with Sony receivers and hence the ignorance on my part.
I dont see any Sony bashing here-just people with inquiring mindsFine. Then, we'll call it "inquiring minds." However, I would suggest that anyone who has questions regarding the Sound and Vision test on the Sony STR-DA4ES - buy the magazine and read the actual test results. Each person will perceive something different after reading it. Clearly, the review was not a negative review - it was just lacking the test results for 5 channels being driven at one time.
Borders along with Barnes & Noble don't have the January 2003 issue on the shelves yet. However, I did find the issue for sale at my local Wal-Mart store.
Maybe the comments were not actual "bashing" comments of the Sony receiver. However, there were some silly comments being made - suggesting that the receiver was in 4 Ohm operation, etc.
Ted, my offer still stands where I will contribute $$ towards the testing if someone would be able to get their 4ES to a private tester to have the output tests performed.
Our standard all-channels-driven power measurement could not be taken because, Sony tells us, the receiver was not designed to deliver full power to all channels simultaneously. Rather, it was designed to exceed the EIA/CEA amplifier specification 490-A, in which each channel is tested individually at full power while all other channels run at one-eighth rated power.What a bunch of losers S&V has become on this one. They make it sound like their equipment wouldn't test it due to an incompatibility with the receiver and they had to go to Sony for the explanation. They could have at least said something like, "We did not perform this test due to requests from the manufacturer. Sony's position is that the receiver was not designed to deliver 110x7 simultaneously, but rather comply with EIA/CEA amplifier specification 490-A which states..."
What a crock... Time to send a nastygram to the editor.
Seth
I also used two Citation 7.1's, an Aragon 8008x5 and a Balanced Audio Technology VK60 as amps. With the exception of the BAT for the smoother tube sound, the difference between the power amps was negligible, no matter what anyone thinks they should have been. They were so close I now don't use an amp.Now thats some high praise for the 4ES. BTW do you still have the amps sitting around or did you already sell them?
However, there were some silly comments being made - suggesting that the receiver was in 4 Ohm operation, etc.Hey, I was just trying to suggest a reason why the 1070 got such a poor test rating in S&V when I have seen it rate much better (~5x70W in 8ohm mode, 5x40W in 4 ohm mode) in other magazine tests :frowning:. The 1070 gets continually bashed in forums on this S&V figure just like the Marantz 7200 gets hammered (on an apparently faulty unit).
...asked me to bring it into the CC show room when I got it so he could show me in a side by side comparison... with the HK AVR 525... Well, the bottom line after the comparison is that I ended up liking the da4es even more. Even the CC rep was impressed. He stated that for the money ($699 shipped) that I could not have gotten a better receiver.I agree. The 4ES is far from perfect, but it is a great receiver for the price. All things considered (including the price), I am quite happy with my purchase.
After I told my Circuit City salesperson (an individual that I have bought from for 4 years now) that I was going with the da4es he was very disappointed and asked me to bring it into the CC show room when I got it so he could show me in a side by side comparison that I should have went with the HK AVR 525. We hooked up each receiver to the same equipment and used the same media to do the comparison. Well, the bottom line after the comparison is that I ended up liking the da4es even more.I have 2 questions about the comparison test:
1) Was the test level matched atleast with an SPL meter?
2) Was the test done in 2 channel (with/without sub) music or 5 channel (with/without sub) HT mode?
I am not asking these questions in offence of the ES or in defence of the HK, but it is very important to control these variables before making any judgement.
There was no SPL meter used. However, the CC Rep and I are not novices either. I believe that we did a good job matching sound output. I understand that there was no way we could get a identical match in sound output with our ears, but after years of demoing equipment I am sure that we were close.You do know that a difference of 0.5 db can skew the results one way or another.
Also the only way, IMHO, to reliably test two amps/receivers is by running them 2 channel direct/full range (without sub). That way you are not hearing the sub amp and are ruling out the variations (voltage and output impedance) between the sub preouts of the two receivers.
I am sure both the 4ES and the 525 are competent pieces of gear with a slightly different sound flavor. Its only a matter of mating it with the right kind of speakers to get the best sound.
