Sony 43HT20 and Toshiba 43H71
Discussion in 'Archived Threads 2001-2004' started by Marvin, Apr 9, 2002.
  1. Marvin
    Marvin Screenwriter
    Apr 9, 1999
    1,481
    42
    1,610
    Marvin
    I know these models have been discussed before but all of the threads were at least a month old so I was wondering if anyone else has had any more recent experiences with one or both of these sets? Any words of caution or encouragement? Is one any better than the other?
    Also, what do owners use for a stand for these sets? The Sony has a custom made stand from Sony but I don't like it (I want a glass door). I don't know if the Toshiba has a dedicated stand. Is anyone using some other brand name stand, e.g. Bush?
  2. Marvin
    Marvin Screenwriter
    Apr 9, 1999
    1,481
    42
    1,610
    Marvin
    Testing...testing...
  3. Leo A. Chimo
    Leo A. Chimo Agent
    May 6, 1999
    25
    1) I have the Sony 43HT20, and am pretty happy with it (although I wish I would have bought a 16:9). My complaints: the "automatic" 16:9 enhanced mode never works automatically when playing back an anamorphic dvd- I have to go into the menu and select "on". Otherwise, beautiful picture, geat controls/imputs. I think the purchase was worth the $. I paired it up with one of JVC's progressive scan players, and have one of the best pictures I have ever seen.
    2) I bought a six-legged coffee table from a used clothing store for $5. It can hold 2 people standing on it, so I figured it would be great for the tv. I plan on building a custom stand in the future. The Sony stand was an additional $300, and I wanted a black stand- not silver.
  4. EarlR
    EarlR Stunt Coordinator
    May 13, 2001
    71
    Hi Marvin
    I have a Toshiba 43HX71 in my sunroom and I am vary happy with it. Toshiba makes a dedicated stand for the 43HX71 and I recommend getting it. The stand has glass doors and one shelf. The stand really works well as it is formed to the TV; it even swivels and matches the color exactly.
    Earl
  5. Carl Normand
    Carl Normand Auditioning
    Jan 22, 2002
    4
    EarlR,
    What is the model number of your stand. I bought the same TV and the stand that normally comes with it here in Canada doesn't have glass doors. Any info would be great.
  6. Marvin
    Marvin Screenwriter
    Apr 9, 1999
    1,481
    42
    1,610
    Marvin
    Carl,
    The stand for the HX71 is ST4361:
    http://www.onecall.com/PID_13084.htm for example. I see the H71's stand is ST4351. They don't have it at Best Buy but I found it after I started this thread at Onecall and several other web sites.
    Thanks for the responses so far (keep 'em coming). It sounds like either TV would be fine. How does regular cable TV look on these projectors?
    One thing I noticed about the Toshiba H71 (not sure if the HX71 is the same) is that it has a very narrow top - too narrow to put a cable box on it. I wonder if there's some sort of adapter piece for this or if you'd have to put the cable box below (in the TV stand) or on a separate stand off to the side.
  7. EarlR
    May 13, 2001
    71
    Carl
    That is the correct part number in fact I got my stand from Onecall as the local representative was out of stock.
    Marvin
    The top is too narrow for a cable box on the HX and I believe there isn’t any difference externally between the H and the HX
    Earl
  8. elMalloc
    elMalloc Supporting Actor
    Dec 26, 2001
    787
    How much did the snake pit cosT?
    (Including all equipment and furnishing?)
    Want to see if I can ever consider doing this in life.
    -ELmO
  9. EarlR
    May 13, 2001
    71
    ELmO
    I don't know the total cost I am afraid to add it all up.
    Earl
  10. Marvin
    Marvin Screenwriter
    Apr 9, 1999
    1,481
    42
    1,610
    Marvin
    Well, I'm almost ready to start looking seriously. Perhaps someone will have a good Memorial Day sale. Does anyone else want to add comments about either of these models (or something comparable)? Does the Toshiba have the "ghosting" problem that I keep reading about with other Toshibas? Any reason to avoid either of these 2 models? Thanks!
  11. EarlR
    May 13, 2001
    71
    Marvin
    I haven’t noticed any of the ghosting problems on my set that have been reported about with some other sets.
    Earl
