JimmyAGR
- May 28, 2002
Hi All,
I finally bought a Radio Shack spl meter, and I was trying to set the speaker levels last night on my Sony 3ES. I went thru the manual and tried following the instructions. Not an easy task with this manual. When I was sending the signal to all the speakers one at a time and adjusting them it seemes like it adjusted each speaker. Then when I moved on to the opposing speaker and adjusted it seems to have changed the settings for the pair. If I adjusted the RR speaker then moved to the LR speaker it seemed to change the level or RR again. Is this the way it works? Do I then have to adjust the balance to make up the difference? Any info you can give on the procedure will be greatly appreciated. If it matters I was using the test tones from the receiver, as the Avia disk is in the mail.
Thanks All,
Jimmy
Thanks All,
Jimmy
