Sony 36" XBR or Sony KP43HT20? Which one would you choose? (1 Viewer)
Scott_E
I am having a difficult time deciding between these two choices. Of course, the 43" is bigger, but I'm not sure how much that makes a difference in my decision. I mostly play video games, watch some DVD's every now and then. Cable sometimes. I want a 4:3 TV. I am not partial to the widescreen ones whatsoever at all. I am worried slightly about burnin on the 43, but I'm not sure if I would get it or not. Which one would you choose? Any points anyone would like to hit on either one of them? Or can you recommend any other brand or model you think I should look at?
Todd smith
Wow, these are the exact two sets that I have been debating between and am also a gamer. Burn in concerns me from everything I have read about which is why I am going with the xbr set. In my mind, If I have to worry about taking a break every hour so my tv does not get burn in it takes away from the experience. One reason I like to play games is to loose track of time, not be concerned with it. It is not worth the risk in my mind. Just my thoughts.
CodeineD1
