1. The HTF Tapatalk application has been discontinued. Please see the thread in the Forum Help & Feedback area for more information.
Sony 36" FS13 16:9 question
Discussion in 'Archived Threads 2001-2004' started by Mac, Dec 27, 2001.
  1. Mac
    Mac Agent
    Feb 17, 1999
    42
    I just purchased a Sony 36" FS13 which will arrive on Saturday. I bought it mostly for the 16:9 compression that allows me to watch anamorphic DVD's in their full glory. My question is do I need to set my DVD player to 16:9 or 4:3 to accomplish this? And if I have to set it to 16:9, do I have to reset it to 4:3 when I am watching a DVD that is not anamorphic? It is bad enough that the Sony does not have auto detection and you have to use your remote to select 16:9, but if I also have to do that with the DVD player, that is getting a little rediculous. My wife will never be able to figure that out. Thanks.
    Mac
  2. Marc Rochkind
    Marc Rochkind Second Unit
    Aug 26, 2000
    381
    You set your DVD to 16:9 full time. For non-anamorphic DVDs, they are full frame (4:3) and there is nothing special for the DVD player to do.
    The difference between the 4:3 and 16:9 settings in the DVD player is only for anamorphic DVDs: Letterbox them, or send the anamorphic image out unchanged. You want the latter.
  3. Mac
    Mac Agent
    Feb 17, 1999
    42
    Marc
    There are quite a few DVD's that are non-anamorphic but are widescreen, either 1.85 or 2.35. Are you saying that the 16:9 setting in the DVD player only applies to anamorphic DVD's, so if it is non-anamorphic it will be letterboxed on the TV?
    Mac
  4. KevinO
    KevinO Stunt Coordinator
    Mar 17, 2001
    76
    You will set your DVD player to 16:9 and you will not have to change it. Anamorphic DVDs will look correct as long as you use the "16x9 Enhanced" mode on the WEGA. Non-anamorphic letterboxed and full-frame DVDs will also be shown correctly without having to change any settings on the DVD player.
