Sony 32FS100 Power On question (1 Viewer)
Joshua_Y
If anyone owns this TV...could you tell me if it makes a very loud noise when it comes on...because mine makes a very loud CLICK noise and was wondering if its normal...
Jack Briggs
If it's just a "click" then you have a quieter-than-usual Sony. That's the degaussing kicking in. Most direct-view Sonys make a loud thumping noise at power-up. Normal.
Joshua_Y
Thats what I meant...its a loud WHUMP!
Im not very good with the sound effect works...:D
OttoIsHere
