Sony (32 or 36) XBR250 vs XBR400 ?? (1 Viewer)
Ken Stuart
Hello,
In the 32" and 36" sizes, I see both XBR250 and XBR400 available for purchase.
Can anyone comment on the difference between these two?
And, if you can compare those to the upcoming XBR450, all the better.
Thanks!
I had the XBR250. It was not HDTV capable and the XBR400 is. I would say that's probably the biggest change.
On my XBR250, I had some geometry problems and uneven brightness across the screen during dark scenes. I think Sony worked out some of these problems for the XBR400s.
I'm not familiar with the XBR450 yet.
Chris
vasyear
