Sony 1000es Help Needed! (1 Viewer)
Heath V
Hello all.
I have picked up this unit and am having a hard time changing the IR signal from AV2 to AV1. I can change the remote without issues, but the receiver does not seem to allow this easily. Can someone help me with it?
For the remote, if anyone needs to change it:
Hold USE MODE button on Remote. Press POWER until the remote display shows "MAIN". Use the input selected to press enter. AV2 will be displayed. Use the input selecter to change to AV1 and press enter using input selecter.
Heath
vasyear
