Sonotube Web Page including lots of pics (1 Viewer)
warrick
OK Folks,
I have finally put a page together showing the construction of My sonosub
Any comments welcome
Hope you enjoy
Warrick
Link Removed :D :D :D
Cam S
Dam that's a nice sub. Seriously rival's the SVS's in the Sonotube looks department, GREAT WORK!
Chris Tsutsui
I'm impressed if that's you in the pic warrick. j/k
Your site inspires me, I'm going to use some of your coding for mine.
Looks pro, have you made a review of how it sounds?
Clay Autery
The remote idea looks like something I might want to use on my "coffee table sub"...
Could you give me some info on it?
warrick
The Photo is my son and he is just a Mini-Me
The web page is my first effort, still a few things to put there like a back button in the construction area.
I will make a review of its performance when I have worked out exactly how to test it, I'm a bit wary after blowing up the first driver.
regards
Warrick
Clay Autery
Actually, I was referring to info on the remote itself... Is there a web page that describes its features, functions, etc...
I'm building my sub to mimic a coffee table (down-firing), and I'd like to mount the amp either on the bottom (not likely... heat) or under a matching cloth covered grill where it will be unobtrusive. I'd like to be able to integrate the sub controls into my Pronto menus...
eric nyhof
the remote is part of a Parts express amp, just like the PE 250 but with the remote, check this out
it's only a few dollars more than the regular 250 watt amp.
