Mark>Som
- Dec 3, 2003
What are the pro's and con's to using a sonotube Vs. a MDF cube (some areas to compare are cost, sound, quality, tight sound, loose sound or any other category needed). I plan on using a 12" driver with a 250 watt plate amp. I will be using this setup for 90% home theater. Therefore, I want to go with a 4.0 CUFT design vented. I have read many things about both but, wanted to know if this is better to use a cylinder in lie of a cube. I thought the DIYers would know best.
I have a 46" widescreen, built into the wall, with two above spaces (both spaces are 16 inches wide by 24 inches tall) for DVD, VCR and associated shelving, ect...I was planning on placing the sub behind the T.V. and covering the back of the upper spaces with grill cloth (the areas behind the T.V. is 4 foot wide by 4 high and 23 inches deep). This would allow the sound to be heard and felt but not seen. However, I am not sure what affect this will have on the T.V.
Please help if you can.
Thanks in advance.
MS
Thanks in advance.
MS
