Sonotube design hypothetical
Discussion in 'Archived Threads 2001-2004' started by TimForman, Mar 5, 2003.
  1. TimForman
    TimForman Supporting Actor
    Dec 4, 2002
    847
    What if a Sonotube sub design incorportated a PR rather than a port? For example, a 72" long tube, downward firing driver, upward facing PR on the other end. Can this be software modeled or has anybody tried it?
  2. no...
    PR's are ONLY..i repeat..ONLY for vertical mounting.
    THe weight and soft suspension would cause the PR rest at it's at its mechanical excurision limit.
  3. TimForman
    Dec 4, 2002
    847
    I was thinking the same thing as I was typing but went ahead anyway. Thanks for the reply.
  4. Jeremy Stockwell
    Jeremy Stockwell Supporting Actor
    Aug 9, 2001
    608
    Should work if you lay the tube on it's side, though. Even I wouldn't want 6ft of Sonotube in the corner of my living room. On it's side might be the best option anyway.
    There somebody around here that made a long table using sonotube on its side. Search function isn't working now, I'll try to find a link later.
    JKS
  5. TimForman
    Dec 4, 2002
    847
    Were you thinking of this guy? A PR could be used in this setup. I wonder what the benefit would be? Hideaway Sub
    You may not want a 6 ft sub in your room but I'm seriously thinging of doing this, without the PR though. I'm thinking....Roman Column..Yeah, that's it.
