Sonotube Damping
Discussion in 'Archived Threads 2001-2004' started by Jason Pannell, Aug 28, 2001.
  1. Jason Pannell
    Jason Pannell Auditioning
    Aug 20, 2001
    14
    Would it be acceptable to use a spray bedliner material to damp the inside of an sonosub, instead of the traditional batting. Is it absolutely neccesary to damp the inside of the tube or is this critical only with the taller versions.
    Jason Pannell
  2. ThomasW
    ThomasW Cinematographer
    Nov 6, 1999
    2,282
    Jason
    The bedliner material won't be of any significant benefit for a tube sub.
    Adding dacron batting or fibreglass batts will abosorb the higher frequencies that aren't filtered by the crossover, and they can be helpful with potential standing waves.
    My experience is that all subs benefit from the addition of damping materials.
  3. Brian Fellmeth
    Jul 30, 2000
    789
    I sprayed some bedliner in mine and wish I hadn't. It was goey with an asphalt smell that took a long time to dry. Since the unit is sealed, i worry about trapped fumes from the bedliner harming the rubber portions of the driver.
