Sonnie,BruceK, BFD gurus, a little help.
Discussion in 'Archived Threads 2001-2004' started by Steve Morgan, Apr 14, 2002.
  1. Steve Morgan
    Steve Morgan Second Unit
    Nov 10, 1999
    328
    Farm in Kansas
    Steve
    I just changed pre/pros should I reset the sub output to the BFD and retake readings or just set the sub output to the BFD so it does not clip? I went from the B&K Ref 30 to the Lexicon MC-1 if it makes a difference.
  2. John Sully
    John Sully Stunt Coordinator
    Feb 25, 1999
    199
    A new pre/pro is not going to change the room response of you sub (unless you moved the sub), so I would say just reset the input level of the BFD and be happy!
  3. Sonnie Parker
    Sonnie Parker Second Unit
    Dec 11, 2001
    407
    Steve, nice upgrade. Nothing shabby about either of those pre/pro's.
    The signal does travel through the pre/pro so there is a chance that there could be a difference, although with the quality of pre/pro's you have, I would not think it would be significant.
    I'd re-measure just for the heck of it. I'd be interested to know (as a fact) if it were different. Let us know!
