Something I haven't understood about HDR (1 Viewer)
Konstantinos
Konstantinos
Excuse me for starting a new thread about this. Didn't know where to post my question.
I haven't understood something about UHDs and this HDR business.
I have a 43 inch 4K monitor that doesn't support HDR.
So, is it possible for me to watch UHDs with this screen (of course I should have a UHD bluray drive) or not?
Because I see occassionally some screenshots of UHDs that are desaturated (with no HDR) and I thought that I'll be seeing a movie like that?
You will need a 4K/UHD drive or player to watch a 4K disc on your current display without any UHD format such as HDR or Dolby Vision.
Konstantinos
Konstantinos
Thanks. I was just baffled why when you take a screenshot from a UHD disc it's desaturated like this. anyway...
Worth
Nick Dobbs
I have a UHD player hooked up to a 60" 1080p Panasonic plasma and I don't see anything resembling the images above, though some players are apparently better than others at converting HDR to SDR. I only have about a dozen or so discs, but they all look excellent with no colour or contrast issues. The only thing I've noticed is that some daylight shots on Starship Troopers look a little blown out, but the 4K disc is still a noticeable improvement over the old blu-ray on my system.
Jeff Cooper
Little Elm, TX
Jeff Cooper
What I'm baffled about is how they can show me the side by side comparison of what 1080p vs UHD and HDR and non HDR looks like on a standard 1080p tv!! :huh:
TonyD
Who do we think I am?
Gulf Coast
Tony D.
I watch UHD discs on my 5 year old 80" flat screen using the sony x800 and have found anything with HDR seems to be too too dark.
Die Hard was almost unwatchable without doing some serious tweeking.
I have HDR turned off on the player as far as I can tell but it's still too dark.
Malcolm R
Malcolm
I've watched a couple 4K (presumably HDR) discs on my non-4K projector and haven't noticed any issues with the video quality (it looks very good).
Worth
Nick Dobbs
It's not really the TV that's the issue - it's the way the player converts HDR to SDR. The Panasonic player that I have seems to do a very good job.
Reed Grele
Beacon Falls, CT
Reed Grele
I watched 2001 UHD on my Panny 7000 projector (1080p) the other night. It looked fine (to my eyes) and sounded incredible!
Still waiting for either 77"+ 4K OLED prices to drop significantly, or I'm enticed by a 4K projector with crosstalk free 3D capability that's in my price range to arrive before I get completely into the world of 4K.
Meanwhile, one of the biggest benefits of watching 4K down converted to 1080p on my current system is that solid color banding artifacts are significantly reduced.
Konstantinos
Konstantinos
From what I've been told elsewhere I need to convert HDR to SDR in a nonHDR monitor.
I thought that the screen will do it by itself, but apparently they said I need a filter or something like madVR which works with Media Player Classic.
Sam Posten
Aberdeen, MD & Navesink, NJ
Sam Posten
This whole thread seems to be crazy talk. You don't need anything other than the disk, the deck and your TV. If your TV does not support HDR then no HDR content will be sent to it. It gets negotiated by HDMI handshaking.
John Dirk
ATL
JOHN
Thanks for boiling it down, Sam. Respectfully, I wouldn't call it "crazy talk" as I suspect the OP [like me] wasn't aware of the simple truth you just shared. I have also been wondering about this. Some of the HDR discs I've recently viewed on my [non-HDR] Panasonic 8000 projector seemed seriously lacking on the video front while others looked fine. Is it fair to say HDR content is intended to be viewed on a compatible display and that acceptable image quality cannot be guaranteed if the display isn't HDR capable?
Sam Posten
Sam Posten
No, it really isn't. The non-HDR content is the base layer. It's the default. The HDR content is added on TOP of that. It's not like there are two seperate encodes.
If you are watching SDR content and it looks bad it's either bad for everyone or a problem with your calibration.
John Dirk
ATL
JOHN
Understood. A non-HDR display like mine will just ignore the encoded metadata in HDR content. To my eyes, native SDR 1080P content generally looks better on my display than 4K HDR content. Maybe it has more to do with Wide Color Gamut? I'm definitely still learning but hopefully I'll have my 4K HDR capable display relatively soon so I'm not overly concerned.
Sam Posten
Sam Posten
It’s possible you have a misconfiguration on WCG content. Check your display’s recommended settings. Does your set actually support WCG?
John Dirk
ATL
JOHN
I'm sorry as I suspect my previous post may have been misleading. I have a Panasonic PT-AE8000 projector [circa 2012], so no, it has no idea what WCG is. That's why I said it might account for the excessive darkness I see in some HDR content.
Sam Posten
Sam Posten
Again, I don't think so, it's likely just a calibration problem. I don't know if wide color can be defeated at the source like it can on most displays that support it.
Lockheede
