Something I don't understand....
Discussion in 'AV Receivers' started by Justin_D, Feb 1, 2004.
  1. Justin_D
    Justin_D Stunt Coordinator
    Dec 27, 2003
    217
    I know how some of the lower end Sonys and other brands say they power speakers @ 100w x 6 @ 8 ohm rms and higher at lower resistance. But realistically, its more like 35 watts per channel rms.
    I understand thats the way it is, but my question is this: How can they get away with advertising 100wpc? Wouldn't that be false advertising?
  2. gene c
    gene c Producer
    Aug 5, 2003
    5,853
    52
    9,110
    Bay area, Ca
    Gene
    False? Sure. Illegal? Probably not. It most likely it will put out 100 wpc but with so much distortion it's un-listenable. Some really cheap receivers will say "100 wpc @ 10% thd, 1khz into 8 ohms." Reality is more like 25 wpc @ 1% thd. Anything over 1% thd sounds bad. My H/K 520 is 75 wpc @
  3. John S
    John S Producer
    Nov 4, 2003
    5,460
    Those numbers can be fudged one way or another, they can make them say anything they want really....
    In the end, most quality equipment, powers speakers just fine, and it is not so much of a factor in real world use.
  4. BrianWoerndle
    BrianWoerndle Supporting Actor
    Feb 19, 2002
    794
    There are too many variables in power ratings. There is THD (total distortion), Frequency (A 1khz note is easier to play than others), # of channels (most only use 1 channel at a time), ohms, and time (anything can put out 100 watts for a fraction of a second).
