Some way to stop speaker rattle?
Discussion in 'Archived Threads 2001-2004' started by John Parris, Aug 26, 2002.
  1. John Parris
    John Parris Stunt Coordinator
    Aug 10, 2002
    235
    Well, I love my JBL S-312s with the exception of the large rattle produced at high volumes...
    The rattle is coming from certain areas of the wall panels and ceiling in my room. The ceiling has removable tiles, so getting up there is no problem... any suggestions on how to remedy this are welcome.
  2. Dave Poehlman
    Dave Poehlman Producer
    Mar 8, 2000
    3,813
    Well, the best thing to do is try and make everything as tight as possible. Ie: if there are pipes rattling, go get some of that black foam pipe insulation and place a piece wherever your pipes touch something else.
    As far as ceiling panels rattling, you might want to try some of that gummy poster hanging stuff. You know, it looks like silly putty and is sticky but can be removed if necessary (you probably don't want to try 2 sided tape as that might tear up your tiles if you try to remove them).
    Just try and localize exactly where the rattles are coming from.
