some questions.. (1 Viewer)
Cameron Garrett
Hi,
Right now I'm currently looking to upgrade my system. The problem is I don't know what to upgrade. Currently im using B&W DM 303 speakers with a Yamaha HTR 5440 receiver, and the sony sawm40 sub.
1st choice:
Upgrade to Axiom M22ti mains. But would it be a significant upgrade over the 303?
2nd choice:
Instead of upgrading my mains, should I upgrade my sub and get an SVS 25-31PCI?
Third choice: Right now I don't have a cd player. I'm wondering if maybe I should save the sub/speaker upgrades for later and buy a decent cd player first?
-Cameron
Jim Hubbard
I own axiom speakers and they are outstanding. However, I would say you are more in need of a decent subwoofer or a DVD/CD player. Also, from everything I have heard, the B&W 303s are fine speakers.
First, spend $200 to get a Panasonic RP56 DVD/CD player. (This is if you are also using TV, if not, maybe someone will let you know of a good CD only player).
Upgrade the sub next to a PCi 25-31 or 20-39 next.
Good Luck!
Cameron Garrett
Thats exactly what I was thinking. Thanks for your input Jim.
S205449
