Some pictures of my Tempest enclosure progress...almost finished
Discussion in 'Home Theater Projects' started by Mattak, Dec 26, 2003.
  1. Mattak
    Mattak Stunt Coordinator
    Dec 15, 2003
    247
    Some pictures from earlier. Both ends are now screwed on as well as the legs. I might have gone overboard with screw placement (every 4 inches)...I'll have to pick up another box of 100 at the rate I'm using them [​IMG]
    I took the initiative of dado'ing the inner walls and center brace so the braces slid right in with no ability to slip out of place. Everything fit together perfectly the first time, I was rather happy about that [​IMG]. This thing is huge and a beast to lift, and I haven't got the sub or amp installed yet[​IMG]
    Sub pictures
  2. Wayne Ernst
    Wayne Ernst Cinematographer
    Feb 24, 2002
    2,588
    Matt,
    It looks like you did a great job on the dado work for the braces. I'm sure that cabinet won't go anywhere when you are finished. In the pictures, I noticed discarded Mountain Dew and Coke cans. Aside from the MDF, the beverages are the most important part of a box construction.
    Enjoy !! [​IMG]
  3. Rory Buszka
    Rory Buszka Supporting Actor
    Jun 5, 2002
    784
    How thick is your material? I have plans for a sub based on the Stryke AV12 in a 2 cubic foot vented box, and I am planning double-layered 3/4" MDF for the exterior walls and two shelf braces.
  4. Mattak
    Dec 15, 2003
    247
    3/4" MDF all around. I think I may have gone overboard with the screws...every 4" at the edges and to the braces [​IMG]
    It goes low, very low [​IMG] It's a little too late to play it to any extent right now, I'll have to test it out more tomorrow [​IMG] Here are a few more pictures of the pretty much finished product.
    Sub pictures
  5. GrahamT
    GrahamT Supporting Actor
    Sep 13, 2003
    556
    Is that the Adire Alignment? Currently I am completing my EBS alginment and am waiting for the ports. Glad to hear it goes low because that was my goal. Nice router and dado work. Building a sub is harder than it looks.
  6. Mattak
    Dec 15, 2003
    247
    It's a cross between the SBB4 and Adire Alignment (24"x24"x33.5").
  7. darren_s
    darren_s Agent
    Dec 21, 2003
    30
    looks good, I just got done filling in screw holes on my EBS shiva box and its the hardest part of whole project next time no screws for me, took 3 coats of wood filler to get it ready for finish.
  8. Owen Bartley
    Owen Bartley Second Unit
    Nov 11, 2002
    487
    Mattak, did you take your pictures off? They aren't working for me and I wanted to see the finished box...
  9. Mattak
    Dec 15, 2003
    247
  10. Rick Westfall
    Rick Westfall Stunt Coordinator
    Dec 8, 1998
    220
    Nice work. I know this probably sounds stupid...but what did you use to trace a circle big enough for that driver. My creativity is a little lacking at the moment.
    Rick
  11. Benihana
    Benihana Stunt Coordinator
    Nov 14, 2003
    190
    if you have olympic weights, a 35lb weight is exactly 14" diameter, i used that to cut the hole for a tempest, then i used a jigsaw to cut it out.
  12. Joey Skinner
    Joey Skinner Second Unit
    Sep 12, 2003
    339
    The easiest way to trace a circle is with a compass. Cheap, in the school supplies section.
  13. DaveKahler
    DaveKahler Stunt Coordinator
    Nov 23, 2002
    73
    If your compass cannot go big enough, put a nail in at the center of the circle, tie or glue a string to it, put a pencil at the radius point, and tie the other end of the string to the pencil. Trace circle.
  14. Rick Westfall
    Dec 8, 1998
    220
    I should trust myself more...all things that I thought might work, but didn't want to spend hours tracing a stupid circle [​IMG]
