Some more Ipod questions
Discussion in 'Playback Devices' started by Reid K, Sep 30, 2003.
  1. Reid K
    Reid K Stunt Coordinator
    Jan 16, 2003
    207
    After reading a bit about the older ones I learned that after a while the unit would get kinda wonky (battery life would get messed up etc) and was wonderin if this was fixed in the new ones. Also right now I have a nomad 2c and the screen is just about completly filled with dust, and was wondering if this will happen with an Ipod. Finally i was wondering is it worth $90 (canadian) extra to upgrade from the 10 gig version to the 15 gig version, keeping in mind with this upgrade I would also get the docking port, remote, and case which dont come with the 10 gig version. Thank you in advance to anyone who can help out.
  2. Rob Speicher
    Rob Speicher Supporting Actor
    Nov 24, 2000
    935
    I've had my 15GB iPod for a few months now. I haven't noticed any irregularities with the battery life, it still lasts a few hours. Limiting the time the backlight stays on also helps preserve the battery quite a bit. Do you mean dust inside the screen? No, never seen that happen on my iPod. It's probably worth the extra money if you wanted those things anyway. Of the 3 accessories, I only really use the docking port, which is very nice and handy. The remote combined with the headphones is actually too long to make it useful to me at 6'1", and I find actually wearing the belt clip case tacky.
    That said, there's a great iPod forum at http://www.ipodlounge.com where you should be able to get some answers from long-time owners.
  3. Troy*H
    Troy*H Stunt Coordinator
    Feb 13, 2003
    156
    I had a 3rd gen 15 gig ipod that died on me last week. Good thing I bought an extended warranty from BB. So I didn't make the same mistake the same time buying another ipod. I bought the new creative nomad zen nx 30 gig for less than the ipod 15 gig. Other than being a little bit bigger( I still wear it when I go lifting and don't have any problems)and not having a "cool" screen" like the ipod, I think the zen nx is the way to go.
    The face plate comes off so I can change the battery if it fails...unlike apple I don't have to practically pay for a new one so they can throw a $40 battery in it.
    the zen doesn't get scratched from breathing on it
    More HD space for the money
    Sounds worlds better than ipod 50mw r and l I believe and 98sd too.
    .....who am I kidding I wish I would have bought the iriver [​IMG]
  4. Marc_J
    Marc_J Auditioning
    Sep 10, 2003
    2
    I've got a 5 gig ipod that I've been using regularly for a year and a half. The decreasing battery voltage issue was fixed in a software update (it was reading a voltage drop wrong and the unit would shut down). I haven't had any problems with mine. The only thing I've noticed is that the load time for music is a little slower than when new, but I think that this is because I've never defragmented it (and I turn over a ton of music and keep it full). ymmv of course.
  5. JamesHl
    JamesHl Supporting Actor
    May 8, 2003
    813
    I've had a 30gig for a couple months and it's been great. I don't think the $90 is worth the extra accessories, but if you think you'll use the space then go for it. The remote and the docking port are kind of cool, but I don't use mine terribly much.
    Isn't the step up to 20gigs and not 15gigs now?
  6. Troy*H
    Feb 13, 2003
    156
    yah I believe so. 20 replaces the 15 and 40 replaces the 30.
