Scott Ryan
- Nov 20, 2002
Hello,
I am starting to finish off my lower level. I'm looking to move my HT down to it and build it in.
The room is 24 x 15 x 9. The floor is concrete with pad and carpet. The walls are 2x6 stud walls with two windows down one long wall, a door 2/3'rds of the way down the other long wall, and a door on the back wall. The front wall will have a fireplace in the center with custom cabinets/shelves on either side.
In the cabinets will by my current Integra DTR 9.1 with a new Sony DVD player, a VCR, and a HD satellite box.
I will be installing a 50" plasma display over the fireplace. For my side and rear surrounds I will be re-using my Def Tech BPX's that I already have.
I currently have Def Tech BP2000TL's for my mains and a CLR1000 for the center. We really don't want free standing main speakers in this room as we are looking for a clean look to the room.
Could you give me some ideas for a quality "in wall" speaker I could use for my mains. I would build them into the cabinets on either side of the fireplace. I'd also like a matching center channel. Looking to spend up to $2,500 retail on these three speakers.
As for the sub, I think we will end up with one free standing in the room. My wife likes a cube style like the Def Tech Super Cube 1, or the Sunfire. I like the SVS, she doesn't because of it's size. If I can talk her into it, could I get by with one SVS 20-39PC+ in a room this size? We don't crank the HT up to reference levels very often. We just want some great sound with tight clean bass.
Thanks for any replies.
