Some confusion with the RP91 (1 Viewer)
David Giesbrecht
On the panny website it says that the RP91 does not have a digital optical output for AC3/DTS but farther down the spec sheet it says it does have an optical/coax output.
Am I missing something?
greg_t
Dmitry is correct. It has both coax and optical. You can't put much faith in Panasonics online spec sheets because they are frequently wrong.
TheThrillisgone
