Solution for beige DVD-R drive & black case?
Discussion in 'Archived Threads 2001-2004' started by Rob Gardiner, Mar 3, 2003.
  1. Rob Gardiner
    Rob Gardiner Cinematographer
    Feb 15, 2002
    2,950
    Hi everybody,
    I'm putting together a video workstation at the office where I work. The DVD-R drive I have picked out is the Sony DRU500A, which burns every possible DVD-R, +R variation. Unforunately it appears to come only in beige, while I was hoping for a black case. Is it possible to replace the faceplate on this drive so the colors will match? Many thanks
  2. Kyle McKnight
    Kyle McKnight Cinematographer
    Mar 8, 2001
    2,504
    I dunno about changing the faceplate, but as you probably already thought about, you could paint it.
  3. John_Berger
    John_Berger Cinematographer
    Nov 1, 2001
    2,489
    I don't know of any manufacturer that offers removable face plates for standard CD/DVD ROM drives.
    I would also suggest painting. It's a lot less work with no risk of breaking any parts. A lot of people have painted their systems for their case mods. Just make sure to use a good primer first since paint might not adhere well to bare plastic.
  4. TyC
    TyC Stunt Coordinator
    Nov 4, 2001
    184
    What about vinyl dye? Also, the DRU-500A is white instead of beige (it stands out in stark contrast to my beige case).
  5. Vince Maskeeper
    Vince Maskeeper Producer
    Jan 18, 1999
    6,499
    Use Vinyl dye. I have done it, it is a common tweak. The face and drawer face have tabs that can release them. Vinyl dye will soak into the plastic, not sit on the surface like paint.
    Summit Racing has vinyl dye spray cheap.
    -Vince
  6. Rob Gardiner
    Feb 15, 2002
    2,950
    Thanks everybody, I will try the dye! [​IMG]
  7. Ted Lee
    Ted Lee Lead Actor
    May 8, 2001
    8,390
    i'm in the same boat. my antec case is grey, but all my stuff is beige.
    is this vinyl dye stuff available at a b&m store? how does it handle little volume wheels, etc?
    btw, here's the place (i think) vince was talking about: http://store.summitracing.com/defaul...D6%26s%3D 180
  8. Vince Maskeeper
    Jan 18, 1999
    6,499
    Most autoparts places have it. I have had good luck with the VHT brand that summit carries. I can't say anything about other brands- so if your local autoparts place doesn't carry VHT, you can either risk it, or spend $8 on the summit stuff.
    I don't bother with the little wheel. The button can usually be popped off too and dyed. The face plate and drawer face usually have tabs that allow them to be removed- the wheel and the nutton usually stay attached to the face (this depends on drive.
    If you do some searches on AVS- I recall seeing a tutorial website with some pics.
    -vince
  9. Ted Lee
    Ted Lee Lead Actor
    May 8, 2001
    8,390
    thx vince - i'll check out avs too!
