Solder-on banana plugs?
Discussion in 'Archived Threads 2001-2004' started by Rudy H, Jun 18, 2002.
  1. Rudy H
    Rudy H Stunt Coordinator
    Mar 2, 2002
    105
    Anybody know where I could find some?
    TIA,
    Rudy
  2. Pete Jennings
    Pete Jennings Second Unit
    Sep 13, 1999
    333
    110
    Vampire Wire makes some bananas that can be crimped or soldered. Radio Shack sells the same plugs under their name. They are very sturdy, and although the description says "crimp" they are easy to solder. They are very inexpensive, in the US they are $3.99 a pair.
    Good luck!
    Pete
  3. Rudy H
    Mar 2, 2002
    105
    doh, only up to 12g [​IMG]
    I need something that'll handle up to 8g (my cat5 wire is roguhly 9g [​IMG])
