So what is ONKYO, DOLBY or anyone doing about their fiasco??
Discussion in 'Archived Threads 2001-2004' started by NickSP, Jan 7, 2002.
  1. NickSP
    NickSP Supporting Actor
    May 8, 2001
    569
    It's been quite a while since the JP3 and PH messup. Are any of the companies involved doing any product recalls or anything otherwise? Has anyone read or heard anything new on that? Onkyo still has a stale press re;ease on their site, nothing new!
  2. Selden Ball
    Selden Ball Second Unit
    Mar 1, 2001
    412
    Selden
    Updated firmware is available for downloading for at least some of the high end Onkyo receivers.
    New firmware is also available for Tag McLaren's pre/pro.
    Outlaw's newsletter announced that they delayed releasing their new pre/pro so they could include the fixes.
    I haven't heard anything about any recalls from any company
    (I have a Marantz pre/pro).
    grumble.
  3. Razvan V
    Razvan V Stunt Coordinator
    Aug 28, 2000
    164
    Nick,
    You wrote that "updated firmware is available for downloading for at least some of the high end Onkyo receivers". Where can I download the updated firmware from?
    Razvan
  4. Ted Lee
    Ted Lee Lead Actor
    May 8, 2001
    8,390
    i'm out of the loop here. what's the fiasco?
  5. NickSP
    May 8, 2001
    569
    Razvan,
    Selden wrote that an update is available for higher end receivers. Is there such an update available for the 898?
    Ted,
    Fiasco being that on some Onkyos and other brand of receivers, there were constant Audio dropouts while trying to watch Pearl Harbor and Jurassic Park-III in Dolby Digital.
  6. Gerard Martin
    Gerard Martin Second Unit
    May 22, 2000
    366
    Lets ask and see if we can find out.
  7. BruceD
    BruceD Screenwriter
    Apr 12, 1999
    1,220
    Universal because of their money grabbing greed, has implemented a copy protection scheme in the code area for DD-EX that is causing DD-EX flag recognition software problems with some DVDs on some pre-pros and receivers.
    BruceD
  8. Ken Seeber
    Ken Seeber Supporting Actor
    Nov 5, 1999
    787
    2
    This isn't limited to Universal. Discs from Disney ("Pearl Harbor") and Anchor Bay ("The Stunt Man" and "The Beastmaster") are also affected.
  9. Razvan V
    Aug 28, 2000
    164
    Nick - sorry for the confusion. Is your Onkyo software upgradeable?
    Selden - where can the new firmware be downloaded from?
    Razvan
  10. Luuk Vos
    Luuk Vos Auditioning
    Dec 14, 2001
    11
    So tell me, how do I download new firmware into my TX-DS797?
    Luke
  11. Willem Vos
    Willem Vos Stunt Coordinator
    Nov 14, 2000
    227
    The only receivers upgradeable are most likely the ones equipped with a RS232 connection (or similar).
    I don't think the 797 has one, but I could be mistaken.
  12. Jeffrey_Jones
    Jeffrey_Jones Second Unit
    Nov 6, 2001
    283
    Hello,
    According to Onkyo the only two receivers that are firmware upgradeable are the 989 and the Integra 9.1. The other Integra receivers that have a RS232 port are for control only and cannot be used to upgrade the software.
    I hope I'm wrong but this information does come from Onkyo and is supported in their user manuals.
    Jeff
  13. Luuk Vos
    Dec 14, 2001
    11
    Guys,
    Thanks for responding so adequate. But what I really meant is, how are they going to cope with all the Onkyo's in the field that are NOT upgradable in this way??
    Luke
    B.T.W.: Willem Vos?? W.T.F.? ;-)
  14. Chip E
    Chip E Screenwriter
    Nov 25, 2000
    1,165
    I don't think Onkyo is going to do anything. Really, it's a software issue. It's my take that the software makers will have to alter the encoding appropriatly.
  15. Eric_M
    Eric_M Stunt Coordinator
    Dec 13, 1999
    218
    Great.
    Well I have an Onkyo595 on order only because the store said they will keep replacing it until I get lucky and end up with one that works fine. Supposedly the 696 doesn't have this issue but that is like $300 more.
    If I can't get one that works then I start all over again with a reciever search. That would not be good.
  16. Jeremy Anderson
    Jeremy Anderson Screenwriter
    Nov 23, 1999
    1,049
    I don't really know that Onkyo should go replacing any of their products because of an error on the part of the producers of two DVD's. It isn't Onkyo or Dolby's fault that these studios tried to insert some wierd form of copy-protection into those bitstreams that causes dropouts. If anything, you should be asking for replacement copies of JP3 and Pearl Harbor from their respective studios.
    But... both of these discs have excellent DTS tracks, so what's the problem?
  17. Charles J P
    Charles J P Cinematographer
    Aug 19, 2000
    2,049
    3
    Omaha, NE
    CJ Paul
    I just want a little clarification here. I heard about the PH and JP3 dvds, but someone here mentions that there are some other disks too. Has this been confirmed? and if so, is it because of the same reason? ... improper use of the DD-EX flag for copywrite info?
  18. Rick Radford
    Rick Radford Supporting Actor
    May 12, 2001
    642
  19. Charles J P
    Aug 19, 2000
    2,049
    3
    Omaha, NE
    CJ Paul
  20. Luuk Vos
    Dec 14, 2001
    11
    Again, another thing is that a lot of non region 1 dvd's DON'T have DTS! It seems you guys are a lot better off again. Damn!
    Luke
