So My New Laptop Has Wireless Card- Can I Do Anything Away From Home?
Discussion in 'Computers' started by James Edward, Feb 6, 2006.
  1. James Edward
    James Edward Supporting Actor
    May 1, 2000
    855
    My new laptop has wireless connectivity. Can I go to Starbucks or somewhere that has wi-fi and get on the internet?
    I am completely ignorant in this area- I know that I can set up a wireless system at home, and use my laptop, but what about outside wi-fi usage? Please educate me.
    Thanks for any replies...
  2. DaveD'
    DaveD' Stunt Coordinator
    Oct 26, 2003
    82
    That, and also airports among other places have wifi "hotspots". You basically just search for a connection just like you do when connecting a new computer to your wireless network at home(I pick up my neighbors when I do [​IMG]). Some charge you for use, not really sure how that works(probably prompts for a password, cc#, etc.).
  3. Michael Reuben
    Michael Reuben Studio Mogul
    Feb 12, 1998
    21,763
    2
    That's exactly how it works. And since public wifi hotspots are never secure (at least none that I've encountered), I often wonder why anyone would take the risk of inputting a credit card to get access.
    When my DSL service goes out, as it does from time to time, I can usually pick up one of several nearby wireless signals. But I'm always careful what I send over those connections. No online purchasing, etc.
    M.
  4. James Edward
    May 1, 2000
    855
    OK- So literally, how do I 'pick up' a wireless signal if one is available? Do I just make sure that the wireless receiver is on, and open IE?
  5. Michael Reuben
    Feb 12, 1998
    21,763
    2
    I assume, since it's a new computer, that it's running Windows XP. In its default configuration, XP should detect an active wireless receiver and a new icon will appear on the taskbar. Right-click on that icon for various options, including a list of available wireless networks and status of an existing connection (if any).
    M.
  6. James Edward
    May 1, 2000
    855
    Thank you Dave and Michael.
  7. Bob Graz
    Bob Graz Supporting Actor
    Sep 26, 2002
    798
    Click on your wireless icon. Should come up with a box to view
    wireless networks. Click on that and it'll show you all networks it's seeing.
  8. Stephen Orr
    Stephen Orr Screenwriter
    Mar 14, 1999
    1,099
    I have a question along these lines. The wireless connection in my son's Dell 8600 went bad. It was an 801.b, and we've decided to just put in a 801.g in it. I really would like to try Bluetooth, but am not sure how that would work. Any advice?
  9. Scott Merryfield
    Dec 16, 1998
    12,308
    1,066
    9,110
    Bluetooth is a different type of wireless "network", which is intended for short-range connections between computer devices and peripherals. It is not intended as general-purpose, high bandwidth wireless data communications network. See here for more information.
  10. Diallo B
    Diallo B Screenwriter
    Dec 18, 2002
    1,076
    not to get stuck on the bluetooth tangent;
    i sometimes use my bluetooth cellphone to get an internet connection with my laptop when i am out of range of an wireless network. it is considered a dial up connection according to win xp connection manager. granted max speed is some thing like 130 kb/s. but, in those situations something is better than nothing.
  11. Rob Gardiner
    Rob Gardiner Cinematographer
    Feb 15, 2002
    2,950
    James,
    Starbucks charges for access, but may coffee shops, libraries, and other organizations offer free wi-fi. Do a google search on "free hotspots ny" and I'm sure you will find something.
    Michael,
    In my experience, "g" adapters are more sensitive and reliable than "b" adapters. Your upgrade should result in better connectivity. As others have said, Bluetooth is incompatible, so if you are connecting to a Wi-Fi hotspot, you will need a Wi-Fi (either "b" or "g") adapter.
  12. Michael Reuben
    Feb 12, 1998
    21,763
    2
    I read those in the disjunctive, since rarely is one prompted for both a password and a credit card. The point is, you have to input something to identify you to the system.
    And while some might say I'm overcautious, I don't like to input even a password over an unsecured wireless connection. In those situations where I've had to do so, I change the password as soon as I'm on a secure connection.
    M.
  13. Stephen Orr
    Mar 14, 1999
    1,099
    Got it. Drop the bluetooth angle, don't need it. Thanks!
  14. DougR
    DougR Second Unit
    Jun 15, 1999
    354
