So it turns out my speakers are 6 ohm .......
Discussion in 'Archived Threads 2001-2004' started by Mike Dr, Mar 4, 2002.
  1. Mike Dr
    Mike Dr Stunt Coordinator
    Jul 30, 2000
    171
    I have Tannoy Saturn S8's as mains and it turns out they are 6ohm each .. my receiver is a Marantz SR7000, and it's handling it fairly well. I'm generally satisfied with my system. I was just wondering if this kind of load has any negative impact on sonic quality or power delivery etc.
    thanks
  2. John Morris
    John Morris Guest
    If you can crank it up as loud as you want.... well no, That material doesn't matter.
  3. Michael Yung
    Michael Yung Stunt Coordinator
    Mar 15, 2001
    152
    You receiver should run hotter than if it was supporting 8 ohm speakers. This could be bad if your receiver is not well ventilated. I think the Marantz SR7000 should be sufficient to handle the work at 6 ohm but check with your user guide anyway. So as long as the ventilation is good and the receiver is technically compatible with 6 ohm, the sound quality should be just as good.
  4. Paul Clarke
    Paul Clarke Supporting Actor
    Jan 29, 2002
    998
    As well as the fact that they probably present a 6 Ohm load for very short periods of time at limited frequencies. This usually only becomes a problem with high output peaks. The 7000 should be warm but not real hot.
