Snapper Petition
Discussion in 'Archived Threads 2001-2004' started by Joshua Clinard, Sep 25, 2001.
  1. Joshua Clinard
    Joshua Clinard Screenwriter
    Aug 25, 2000
    1,832
    77
    1,610
    Abilene, TX
    Joshua Clinard
  2. Brian Lawrence
    Brian Lawrence Producer
    Feb 28, 1998
    3,634
    110
    Brian
    [​IMG]
  3. Jeff Kleist
    Dec 4, 1999
    11,267
    Seriously, if you want Snappers gone, you need to collect PAPER signatures. Create a standard form letter for people to snail-mail to Warner. However, as Warner once said to me "Does the snapper keep you from buying the disc?" The answer is usually no [​IMG]
    Jeff Kleist
  4. Mark Zimmer
    Mark Zimmer Producer
    Jun 30, 1997
    4,301
    42
    1,610
    Wasting your time. Warner owns the patent to Snappers. They don't own the patents to other keepcase designs, and they would have to pay royalties to make the cases, or would have to buy them from a 3rd party. Which one do you think is going to appeal most to the bottom line? The snapper is here to stay for Warner.
    "This movie has warped my fragile little mind."
  5. James D S
    James D S Screenwriter
    Nov 14, 2000
    1,000
    Done.
    The way I see it, every little bit helps. Besides, logic would seem to conclude that Warner also owns the rights/patents (or whatever) to snappers in Australia and in Europe, yet they ceased their use despite whatever perceived 'impact' on the bottom there may be.
  6. Roger Mathus
    Roger Mathus Supporting Actor
    Sep 1, 1997
    549
    110
    Central Oregon
    Roger Mathus
    And, Warner has never used snappers in Japan.
  7. Frank Anderson
    Frank Anderson Cinematographer
    Jun 7, 1999
    2,667
    Won't do much good but I agree every little bit helps. I signed it.
    Frank
    [​IMG]
  8. Arttu Salmi
    Arttu Salmi Extra
    Jan 7, 1999
    20
    Warner is releasing their movies in keep cases...in Finland and only for rental. This pisses me off royally.
  9. YANG
    YANG Second Unit
    Feb 10, 1999
    471
    2
    Save your time guys...its no use.There are lots of petitions raised before to get WARNER attention,but all of them failed...at least WARNER AUSTRALIA shows a little bit of interest to the consumers!
