Smallest sonotube to reach 20Hz at -3dB?
Discussion in 'Archived Threads 2001-2004' started by Manuel Delaflor, Jun 29, 2002.
  1. Manuel Delaflor
    Manuel Delaflor Supporting Actor
    May 25, 2001
    657
    Based on the Shiva, Titanic or any other 12 inch driver, have anyone made calculation on the size of the Sonotube required?
    I have noted, for example, that the HSU's are smaller than the SVS's, still, they appear to reach more or less the same output...
  2. Mike_A
    Mike_A Stunt Coordinator
    Oct 7, 2001
    153
    well, don't forget that the HSU's have some EQ applied to them, so they can get away with being smaller. the same prinicple is used in linkwitz (sp?) transforum subs that people have built here, allowing for extremely small sealed subs to be flat down to 20Hz. the disadvantage is that a driver with more excursion and high power handling is needed in addition to an amplifier with lots of power. it's basically the same concept you seen in the high end 1000W velodynes, etc...
  3. Jack Gilvey
    Jack Gilvey Producer
    Mar 13, 1999
    4,948
    Download LspCAD from Adire, figure it out. Shiva parameters are already loaded, it's good to learn.
  4. Patrick Sun
    Patrick Sun Studio Mogul
    Jun 30, 1999
    39,097
    690
    9,110
    And remember, it's not like the sonotube is something special in the way it'll interact with a driver. What you are looking for is the minimum enclosure volume (regardless of it being via a box or sonotube, etc).
  5. Manuel Delaflor
    May 25, 2001
    657
    Mike_A,
    Thanks, I didn't know HSU used an EQ.
    Jack,
    You always impulse me to do it by myself. I have played with the software, but I don't like the approximate curves it draws, I have learned that those curves rarely reflect real world performance. Anyway, thanks, I guess [​IMG]
    Patrick,
    I know the shape has nothing to do with the sound, but I understand also that it is much simplier and a lot less expensive to have an enclosure strong enough to avoid resonances using a tube than a box. Yep, I will try to find the minimum enclosure volume.
  6. Brian Bunge
    Brian Bunge Producer
    Sep 11, 2000
    3,716
    Manuel,
    While a sonotube based sub might be simplier, it's not necessarily less expensive. A sheet of 3/4" MDF costs $20 and should be plenty of material to build most subs including bracing. Of course, if you go huge you'll need more. Some folks have paid upwards of $100 for 24" sonotube and then you still have to buy MDF.
    Brian
  7. Jack Gilvey
    Mar 13, 1999
    4,948
  8. Brian Bunge
    Sep 11, 2000
    3,716
    Jack,
    God, I've missed you around here lately! [​IMG]
    Brian
  9. Mark Seaton
    Mark Seaton Supporting Actor
    Oct 10, 1999
    599
    110
    Mark Seaton
    It should be understood that if you are really set on a -3dB point of 20Hz, from whatever pool of drivers you find which can meet this spec, those lower in efficiency will allow smaller enclosure volumes. This is where the Stryke SA-1204 is a nice solution with a little more power. If you have power, a Brahma sub should get you into even smaller box sizes. Obviously you then run into the problem of adequate porting fitting within the box.
  10. Bob Bartlett
    Bob Bartlett Stunt Coordinator
    Jun 28, 2001
    209
    I found a cheap way to get sonotube is look around construction sites and ask a worker if they have any pieces left over. A construction crew was at my local school and I asked one of the workers and he gave me a 6' piece of 18" tube for free. Just a thought. The local lumberyard wanted $89 for a 12' 18" tube. I can buy 4 sheets of mdf for that.
  11. Jack Gilvey
    Mar 13, 1999
    4,948
    To answer the question, since there's no volume/loudness requirement given, just stick a Shiva in the absolute smallest piece of Sonotube in which it will fit. Seal it up, then EQ it until it's -3dB @ 20Hz. Won't get much louder than a cat fart, but it'll fulfill the requirements of the initial post.
  12. Manuel Delaflor
    May 25, 2001
    657
    Brian Bunge
    In my case, it is really really cheap, I just bought a sonotube, 12 inch and 3 meters tall, I cutted it in three pieces. Total cost? 15 bucks. Today I asked for the price of three cuts on MDF with all the holes needed, it doesn't pass 30 bucks.
    Im searching at this moment for an used home amplifier which I can put in Mono and don't want to pay more than 80 bucks. What I need now is only the driver, I will begin my experiments with national (Im in Mexico) drivers which cost from 14 to 50 bucks, and then, when I feel confortable I will ask for a Shiva or a Tempest and a good amplifier to make my final sub. Cost in here for a box would be higher, around 70 to 150 bucks.
    Jack Gilvey
  13. Brian Bunge
    Sep 11, 2000
    3,716
    Manuel,
    I'm interested in seeing how you plan to mount a 12" driver in a 12" tube! The driver's outside dimensions are usually slightly larger than 12". For instance, a Dayton DVC 12" driver has an external diameter of 12.25", which means it would overhang the outside of the tube. You'd have to make your exterior piece of MDF around 12.5-13" in order to mount the driver. Then you'd see the screws sticking up out of the MDF.
    I don't know of a $15-$40 driver that's going to meet your requirement of -3dB at 20Hz at any audible levels in a home environment.
    Concerning your friend's sub, unless the software you used can simulate the cabin gain that you get when you put a sub in an automobile then there's no wonder you didn't get a response curve anywhere near what the simulation said. The response curve would look absolutely nothing like a simulation that doesn't factor in cabin gain.
    Brian
  14. Jeff Rosz
    Jeff Rosz Second Unit
    Sep 24, 2000
    335
    regarding trusting of software, i think everyone can mostly agree that lspcad is pretty darn accurate. and the cost of using lspcad obtained from adire when using adire drivers cant be beat.
    brian, he could just double up on the thickness of the external driver endcap. a lil mass there wouldnt hurt.
  15. Manuel Delaflor
    May 25, 2001
    657
    Brian,
    I bought the 12" just for begin to experiment, the next step that was available at the store was a 20something, way to big for my first approach.
    The drivers Im seeing for now (again this will be previous to thinking in import a more expensive driver) are 8" and 10", I forgot to mention it!
    Yes, he didn't simulate the cabin gain, his software doesn't allow to do that. And this was his first design too. I wasn't aware that such measure could be introduced in some programs, I will comment him.
    Jeff,
    Thanks for your imput, I will begin to calculate using the version from Adire. Last time I did it was calculating a sealed box for a Tempest, and it was large. Im considering two possibilities at the momement, either a small sonotube, or a closet with concrete walls to do an IB array.
  16. Jack Gilvey
    Mar 13, 1999
    4,948
  17. Manuel Delaflor
    May 25, 2001
    657
    Jack,
    Why ALWAYS this tone in your replies to me? You seem to remember well everything I asked before. Am I stubborn? Or you simply don't like me?
    Why even bother to answer anything I post?
  18. Bryan Michael
    Bryan Michael Supporting Actor
    Mar 2, 2002
    564
    how about a 15 inch driver in a 12 inch tube?
    just buld a box on the end of the tube and you can buld a box on the other end for balance and there you have it a 15 in sub in a 12 in tube
  19. Jack Gilvey
    Mar 13, 1999
    4,948
    My altruism will not diminish despite this abuse.
  20. Hank Frankenberg
    Hank Frankenberg Cinematographer
    Oct 13, 1998
    2,573
    Jack, you're mighty feisty in this thread. Did you have an extra latte at Starbucks? I'm so glad you're hanging onto your altruism - the warmth of your personality would be sorely missed without it. [​IMG]
    I try to ignore the abuse. Notice how much Jawga Brian B. abuses me constantly? I'ts the unrepressed envy - he wishes he lived in Texas. I remain above such pettiness.
