Just wondering if this newer version is out yet. I've looked around and even asked a few stores if they had any info, but no luck yet. Has anyone seen it yet? Thanks. Will
Okay, I understand there are two types of "flipper" discs: DVD-10s and DVD-18s, the latter of which are allegedly more prone to error. Which type are the Battlestar Galactica: Complete Epic Series discs? I ask, because I recently purchased this set, and two of the discs were off the hub. One of the loose discs looked and played fine, but the other one had some scuff marks which could not be rubbed out on one side. That side played fine until the 38th minute of Living Legend Pt. II (less than ten minutes until the end of the disc, in other words), at which point it froze up. I took the disc out, wiped it with a DVD-safe cloth, and it played fine. I finished the episode and went back to the freeze point a second time to see what would happen. Again, it was fine. So, were these the hardier DVD-10s?
