Edward J M
- Sep 22, 2002
If my making JUST the mains Large I am asking the receiver to reproduce bass on all the channel then why would it be necessary to even give the listener the option of setting their surrounds and rear surrounds independent of the main channels? This same question also applies to the center channel, too.Brae:
I think these are all the bass management scenarios the typical HT receiver is capable of handling.
1) If you set the sub to yes, and all the speakers to small, the sub receives the LFE channel, AND the sub also receives bass below your selected crossover frequency from all the other speakers.
2) If you set the sub to yes, and all the speakers to large, the sub only receives the LFE channel, and all the remaining channels receive a discrete full range signal.
3) If you set the sub to yes, and the mains to large, and the remaining speakers to small, the mains receive a discrete full range signal, the sub receives the LFE channel, AND the sub receives the bass below your selected crossover frequency from any speakers set to small.
4) If you set the sub to no, and all the speakers to large, all channels receive a discrete full range signal, AND the LFE channel will be redirected to the mains.
5) If you set the sub to no, and the mains to large, and the remaining channels to small, the mains will receive a discrete full range signal, AND the LFE channel will be redirected to the mains, AND the bass below your selected crossover frequency from any speakers set to small will also be redirected to the mains.
Hope this helps instead of confusing further.
Ed
