Small Theater Layout
Discussion in 'Home Theater Projects' started by Bernie_A, Mar 10, 2004.
  1. Bernie_A
    Bernie_A Stunt Coordinator
    Feb 3, 2004
    112
    My HT is 11x16 w/ 10 cl'gs. I want to go 7.1 and I already have a 5.1 setup so my question is, with this size room: A) Would I really miss not having a 7.1 and B) Would you go bi-pole for the mid-surrounds or just another pair of bookshelves to match my current rear surrounds?
  2. Neil Joseph
    Neil Joseph Lead Actor
    Jan 16, 1998
    8,332
    Neil Joseph
    Your room is the same size as mine. I have 6.1 with quasi dipole surrounds and a monopole (direct radiating rear centre) to anchor the back. With 7.1, I would try to match as many speakers as I could and if this is possible for you, select all mid and rear surrounds as the same type of speaker. if not, then I would get the mid and rear surrounds using the same type of speaker and closelt match the rear centre with a centre speaker with the same tonalities.
  3. Bernie_A
    Feb 3, 2004
    112
    I think I am going to plan for 7.1 and provide speaker wires where they need to go. I like the way it sounds and for right now at least, I am really jonesin hard for a FP. That's going to cost at least 3K +/- $$$$
    Upgrade the sub and I should be good to go for a while.
    The room is going to be a single car garage converted into HT. It's got drywall now but not insulated. The door is coming off and a window / potshelf added to match the other houses in the tract.
    Opinions on our proposed wall prep: pump sound-proof insulation into the 3 exterior walls, put resilient channels over the existing drywall, 1 layer of sound board and then 1 layer of 5/8" gyp board. Paint
    Opinions on our proposed floor prep: We plan on building up a little subfloor out of wood to flush out the step-down from the house to garage. I have heard that this will result in better bass as well as it will provide another place to run wires, etc.
    Of coarse, we plan on adding a few recessed can lights and a couple wall sconces...all on dimmers.
    I look forward to everyone's ideas as well.
