Small sealed tempest
Discussion in 'Home Theater Projects' started by AjayM, Dec 2, 2003.
  1. AjayM
    AjayM Screenwriter
    Aug 22, 2000
    1,224
    Everybody,
    I'm in need of dropping the size of my current low Q sealed Tempest down to something a little more reasonable for asthetic reasons. Currently the enclosure is around 170-180l, I was looking over some of the "sealed" designs Adire posted and the .9 Q enclosure caught my eye, well the 67l enclosure caught my eye. Modeling that size enclosure with the tempest does give me a small sub 1db peak and an F3 in the high 30Hz range.
    So what would happen if I were to stuff the Tempest into such an enclosure and then try and smooth out the response with my behringer FD? I'm not in need of max SPL nor do I need response down into the brain melting Hz range. Right now with the large enclosure I'm about 3db down at 19/20Hz. What will I lose by going to such a small enclosure and throwing some EQ at it?
    Andrew
  2. GrahamT
    GrahamT Supporting Actor
    Sep 13, 2003
    556
    You will have reduced low frequency extension and efficiency.
  3. KyleGS
    KyleGS Second Unit
    Feb 12, 2002
    342
    I tried out the 67L design and did not like it. It didn't give a flat sound. It sounded very peaky around 40hz- even in my small living room. It still had decent extension on movies but didn't give a good response with music and critical listening. I've tried MANY sealed designs and I've settled on 100L heavily (85%) stuffed. It's pretty flat, good extension, and is relatively small. I wouldn't recommend going any smaller than this. I believe Adire settled on 109L sealed with stuffing for their Daeva sub-->should have a final Q of ~.7 with stuffing.
  4. Robert_Gaither
    Robert_Gaither Screenwriter
    Mar 12, 2002
    1,370
    I'd recommend selling (trading with someone here, or moving it to the car)the Tempest and acquiring a driver that would model better in a smaller cabinet.
