Greg*go
- Jun 14, 2002
I just reinstalled XP into my computer, and although I'm happy overall, I found a few quirks that are annoying me...
First off, Outlook & Win Messenger are in it, and there seems to be no way to delete them. I checked in the Add/Remove section of the Control Panel, as well as their individual folders, and saw no install/uninstall options. Is there anyway I can fully delete these programs?
The other problem I'm having is when the Ctrl Alt Del menu doesn't have a toolbar. I can see what tasks are running, but that's it, I can't go to the processes or CPU Usage or User sections without using the Tab button. Is there a setting I can use to fix this?
Any help is greatly appreciated. Thanks.
